I am working on FMC920. i had connect 6 devices. Everything is working fine.
But the issue is that when i sent SMS command to the device, the command functionality is not working. Although the Device received the SMS, SMS count increases for every SMS that i sent. But the SMS command Functionality is not Working.
Like I sent SMS setparam 107:16 so the device wont able to switch the ignition source to accelerometer. Although the device Received the SMS.
How can i resolve this issue ?
Also when i sent the same GPRS command. The command functionality will work.
Mistakenly i wrote the wrong parameter number here. But i had checked once again. The issue still not resolved.
this time i sent sms command . setparam 138:1 (apply two spaces) but it is not switch the iginiton parameter to ignition, previously it is using accelerometer as the ignition source.
