I recently installed a RUT260 to send email and SMS notifications when faults occur on an Allen Bradley system.
Some simple C# was used to create an email sender and message string, and that works will routing through the RUT260 as a gateway.
However when i attempted to do the same as an SMS gateway, it would not work. Could i please get some information/documentation on how i am best to create an SMS sender that can utilize the RUT260 to send customized messages depending on the conditions identified in the Allen Bradley device?
Since you are already using C# scripts to send emails, the simplest way to add SMS functionality would be to use the API as well.
To avoid the need for session token management, I recommend enabling Basic Authentication on the router. This allows SMS messages to be sent using a single HTTP request.
(However, if you require additional security, you can also use session token authentication. Instructions for that method are available here: Teltonika Networks Web API)
First, you must enable basic authentication on the RUT260 (Firmware version should be newer than 07.19):
Navigate to System → Administration → Access Control
