I try to connect my RUT241 to a SinemaRc Server. But is not working.
Have anybody else try the same ?
Please, provide a bit more information about your use case. How are you trying to connect RUT241 to a SinemaRC server? Are you using a VPN? If so, what VPN are you using and how did you configure it?
If it is a VPN, please share your VPN configurations, as well as VPN logs. Please, before sharing your configurations, make sure that you hide any sensitive information such as public IP addresses, keys, passwords, etc.
If it is not a VPN, please explain how everything is connected and what protocols are used.
