Sim Switcher on rut955
Hey, when i want use the Sim-switch function, i can choose the dBm of the signal, i have a chart to choose how much i need or when its better to switch, but there different codes, what dBm value i have to choose RSSI UVP RSRQ SINR ? i mean isn’t wrote there what of these 4 it means? How i can see this or set it up?
There was a similar topic before here.
Basically, RSSI is the value that indicates the signal strength and it is the parameter that you are interested in.
More information about the mobile signal can be found here.
