SIM card could not be registered and provider could not be found
after the FW update my router could not reach Auto APN and it says:
All available APNs were tried, unable to make connection to operator, try to enter custom APN or adjust mobile settings to make connection.
My MNC+MCC is 26202 (also the first 5-digit of my IMSI). Could there be a solution for that? Thanks in advance
BR
If the AUTO APN doesn’t locate any APN, you can manually set the APN. Navigate to Network → WAN and click “Edit” next to your mobile interface.
In the new window, disable the “Auto APN” option and enter your desired “Custom APN.”
Marijus
Hi Marijus,
I have tried Auto APN and Manuell APN but it didn’t work. The Provider is shown as 000 000.
Besides, I have checked the log data for the last five minutes. I paste it below. Thanks for your support:
root@FASMT11:~# logread
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.000000] Linux version 5.10.199 (app@runner-ffjpezdj-project-352-concurrent-0) (arm-openwrt-linux-mus
lgnueabi-gcc (OpenWrt GCC 8.4.0 r16279-5cc0535800) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Thu Feb 29 09:15:41 2024
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] CPU: div instructions available: patching division code
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] OF: fdt: Machine model: RUTX11 STM32
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Memory policy: Data cache writealloc
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Zone ranges:
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Normal [mem 0x0000000080000000-0x000000008fffffff]
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] HighMem empty
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Movable zone start for each node
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Early memory node ranges
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087dfffff]
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000087e00000-0x0000000087ffffff]
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000088000000-0x000000008fffffff]
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000008fffffff]
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 65536
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] Normal zone: 576 pages used for memmap
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] Normal zone: 65536 pages, LIFO batch:15
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] percpu: Embedded 15 pages/cpu s30924 r8192 d22324 u61440
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s30924 r8192 d22324 u61440 alloc=15*4096
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.000000] Kernel command line: ubi.mtd=rootfs ubi.block=0,1 root=/dev/ubiblock0_1 rootfstype=squashfs
console=ttyMSM0,115200n8 rootwait
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Memory: 247148K/262144K available (6364K kernel code, 613K rwdata, 1616K rodata, 1024K init, 2
39K bss, 14996K reserved, 0K cma-reserved, 0K highmem)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] Tracing variant of Tasks RCU enabled.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 48.00MHz (virt).
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 44
0795203732 ns
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000008] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 4398046511096ns
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000026] Switching to timer-based delay loop, resolution 20ns
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000418] Calibrating delay loop (skipped), value calculated using timer frequency… 96.00 BogoMIPS (lpj
=480000)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000442] CPU: Testing write buffer coherency: ok
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000496] pid_max: default: 32768 minimum: 301
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000674] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.000694] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.002053] qcom_scm: convention: smc legacy
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.003074] Setting up static identity map for 0x80300000 - 0x8030003c
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.003255] rcu: Hierarchical SRCU implementation.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.003537] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.003916] smp: Bringing up secondary CPUs …
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.007636] smp: Brought up 1 node, 4 CPUs
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.007665] SMP: Total of 4 processors activated (384.00 BogoMIPS).
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.007677] CPU: All CPU(s) started in SVC mode.
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 0.011997] Duplicate name in mnfinfo, renamed to “name#1”
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.013908] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.014092] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000
ns
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.014123] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.014367] pinctrl core: initialized pinctrl subsystem
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.016266] NET: Registered protocol family 16
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.016677] DMA: preallocated 256 KiB pool for atomic coherent allocations
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.017831] thermal_sys: Registered thermal governor ‘step_wise’
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.018334] cpuidle: using governor ladder
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.018397] cpuidle: using governor menu
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.046925] cryptd: max_cpu_qlen set to 1000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051588] usbcore: registered new interface driver usbfs
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051678] usbcore: registered new interface driver hub
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051751] usbcore: registered new device driver usb
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051806] pps_core: LinuxPPS API ver. 1 registered
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051818] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.051848] PTP clock support registered
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.053692] clocksource: Switched to clocksource arch_sys_counter
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.054731] NET: Registered protocol family 2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.054983] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.055995] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056051] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056093] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056144] TCP: Hash tables configured (established 2048 bind 2048)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056269] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056318] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056635] NET: Registered protocol family 1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.056686] PCI: CLS 0 bytes, default 64
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.060201] workingset: timestamp_bits=14 max_order=16 bucket_order=2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.064819] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.064846] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc
Thu Feb 29 09:47:40 2024 kern.err kernel: [ 0.210543] bam-dma-engine 8e04000.dma: num-channels unspecified in dt
Thu Feb 29 09:47:40 2024 kern.err kernel: [ 0.210573] bam-dma-engine 8e04000.dma: num-ees unspecified in dt
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.211308] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.211423] tcsr 1953000.ess_tcsr: setting ess interface select = 0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.211519] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.211610] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.211945] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.212552] msm_serial 78af000.serial: msm_serial: detected port #0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.212601] msm_serial 78af000.serial: uartclk = 1843200
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.212656] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 34, base_baud = 115200) is a MSM
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.212691] msm_serial: console setup on port #0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.762449] printk: console [ttyMSM0] enabled
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.767657] msm_serial: driver initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.776702] loop: module loaded
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.777816] spi_qup 78b5000.spi: IN:block:16, fifo:64, OUT:block:16, fifo:64
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 0.779817] spi-nor spi0.0: found xt25f128b, expected n25q128a11
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.786485] spi-nor spi0.0: xt25f128b (16384 Kbytes)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.792075] 16 fixed-partitions partitions found on MTD device spi0.0
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.796931] Creating 16 MTD partitions on “spi0.0”:
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.803232] 0x000000000000-0x000000040000 : “0:SBL1”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.808600] 0x000000040000-0x000000060000 : “0:MIBIB”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.813743] 0x000000060000-0x000000080000 : “0:BOOTCONFIG”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.818574] 0x000000080000-0x0000000a0000 : “0:BOOTCONFIG1”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.824006] 0x0000000a0000-0x000000100000 : “0:QSEE”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.829418] 0x000000100000-0x000000160000 : “0:QSEE_1”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.834657] 0x000000160000-0x000000170000 : “0:CDT”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.839554] 0x000000170000-0x000000180000 : “0:CDT_1”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.844390] 0x000000180000-0x000000190000 : “0:DDRPARAMS”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.849558] 0x000000190000-0x0000001a0000 : “0:APPSBLENV”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.854994] 0x0000001a0000-0x000000240000 : “0:APPSBL”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.860393] 0x000000240000-0x0000002e0000 : “0:APPSBL_1”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.865439] 0x0000002e0000-0x0000002f0000 : “0:ART”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.870798] 0x0000002f0000-0x000000300000 : “0:CONFIG”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.875519] 0x000000300000-0x000000310000 : “0:CONFIG_RW”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.880612] 0x000000310000-0x0000003a0000 : “0:EVENTSLOG”
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.892398] spi-nand spi0.1: XTX SPI NAND XT26G02A was found.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 0.892448] spi-nand spi0.1: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.897422] 2 fixed-partitions partitions found on MTD device spi0.1
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.905324] Creating 2 MTD partitions on “spi0.1”:
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 0.911637] 0x000000000000-0x000008000000 : “rootfs”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 1.333720] random: crng init done
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 1.614908] mtd: setting mtd16 (rootfs) as root device
Thu Feb 29 09:47:40 2024 kern.alert kernel: [ 1.616379] mtdsplit: no squashfs found in “rootfs”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 1.618979] 0x000008000000-0x000010000000 : “rootfs_1”
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.367753] MNFINFO PROPERTIES:
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.367792] mac : 001E423420AD
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.369707] name : RUTX1110XXXX
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.373525] serial : 1112210886
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.377146] hwver : 0808
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.380297] branch :
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.383332] batch : 0025
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.385873] sim_count: 4
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.388714] blver : 2.1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.434289] ESS reset ok!
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 2.508468] ESS reset ok!
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.267252] i2c /dev entries driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.270444] sdhci: Secure Digital Host Controller Interface driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.270483] sdhci: Copyright(c) Pierre Ossman
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.275905] sdhci-pltfm: SDHCI platform and OF driver helper
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.286727] NET: Registered protocol family 10
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.288246] Segment Routing with IPv6
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.290305] NET: Registered protocol family 17
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 3.294062] 8021q: 802.1Q VLAN Support v1.8
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 3.298408] Registering SWP/SWPB emulation handler
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 3.313835] ubi0: attaching mtd16
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.932605] ubi0: scanning is finished
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.975510] ubi0: attached mtd16 (name “rootfs”, size 128 MiB)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.975561] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.980256] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.987170] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 6.994017] ubi0: good PEBs: 1021, bad PEBs: 3, corrupted PEBs: 0
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 7.000740] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 7.007044] ubi0: max/mean erase counter: 14/7, WL threshold: 4096, image sequence number: 1440367834
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 7.014148] ubi0: available PEBs: 0, total reserved PEBs: 1021, PEBs reserved for bad PEB handling: 37
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 7.023442] ubi0: background thread “ubi_bgt0d” started, PID 140
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 7.024440] block ubiblock0_1: created from ubi0:1(rootfs)
Thu Feb 29 09:47:40 2024 kern.err kernel: [ 7.040403] UBI error: block: can’t add ‘rootfs’ volume, err=-17
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 7.068606] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 7.070871] Freeing unused kernel memory: 1024K
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 7.094101] Run /sbin/init as init process
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 7.094161] with arguments:
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 7.094248] /sbin/init
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 7.094320] with environment:
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 7.094397] HOME=/
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 7.094471] TERM=linux
Thu Feb 29 09:47:40 2024 user.info kernel: [ 7.944527] init: Console is alive
Thu Feb 29 09:47:40 2024 user.info kernel: [ 7.944941] init: - watchdog -
Thu Feb 29 09:47:40 2024 user.info kernel: [ 11.712268] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 11.881651] genirq: irq_chip msmgpio did not update eff. affinity mask of irq 101
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 11.914193] STM32 supported protocol: 2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 11.915980] r2ec 0-0074: probed
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 11.922933] gpio-export soc:gpio-export: 5 gpio(s) exported
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 11.938371] SCSI subsystem initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 11.944246] uhci_hcd: USB Universal Host Controller Interface driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.331704] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.331797] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.336692] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f665 hci version 0x100 quirks 0x0000000002010010
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.343820] xhci-hcd xhci-hcd.0.auto: irq 108, io mem 0x08a00000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.353341] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.359341] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.364619] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.372992] hub 1-0:1.0: USB hub found
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.378814] hub 1-0:1.0: 1 port detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.382912] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.389913] hub 2-0:1.0: USB hub found
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.394686] hub 2-0:1.0: 1 port detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.398689] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.402270] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.408036] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f665 hci version 0x100 quirks 0x0000000002010010
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.415200] xhci-hcd xhci-hcd.1.auto: irq 109, io mem 0x06000000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.424692] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.430734] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.436065] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.444409] hub 3-0:1.0: USB hub found
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.450212] hub 3-0:1.0: 1 port detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.455149] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.458792] hub 4-0:1.0: USB hub found
Thu Feb 29 09:47:40 2024 kern.err kernel: [ 12.466147] hub 4-0:1.0: config failed, hub doesn’t have any ports! (err -19)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.482295] usbcore: registered new interface driver usb-storage
Thu Feb 29 09:47:40 2024 user.info kernel: [ 12.482793] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 user.info kernel: [ 12.496498] init: - preinit -
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.703798] usb 1-1: new high-speed USB device number 2 using xhci-hcd
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.948680] hub 1-1:1.0: USB hub found
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 12.949067] hub 1-1:1.0: 4 ports detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 13.333870] usb 1-1.4: new full-speed USB device number 3 using xhci-hcd
Thu Feb 29 09:47:40 2024 user.info kernel: [ 15.068046] mount_root: loading kmods from internal overlay
Thu Feb 29 09:47:40 2024 user.info kernel: [ 15.138546] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 user.info kernel: [ 15.148814] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.221569] UBIFS (ubi0:2): Mounting in unauthenticated mode
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.221896] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 290
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.434794] UBIFS (ubi0:2): recovery needed
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.923768] UBIFS (ubi0:2): recovery completed
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.923955] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.927132] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048
bytes
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.935076] UBIFS (ubi0:2): FS size: 99549184 bytes (94 MiB, 784 LEBs), journal size 4952064 bytes (4 Mi
B, 39 LEBs)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.944972] UBIFS (ubi0:2): reserved for root: 4701953 bytes (4591 KiB)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 17.955206] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 01ED5734-2F14-4D62-9EFE-D78FE977
6E6F, small LPT model
Thu Feb 29 09:47:40 2024 user.info kernel: [ 17.973163] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Thu Feb 29 09:47:40 2024 user.info kernel: [ 18.018784] block: extroot: not configured
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.019417] UBIFS (ubi0:2): un-mount UBI device 0
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.021933] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” stops
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.036757] UBIFS (ubi0:2): Mounting in unauthenticated mode
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.037062] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 291
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.483574] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.483635] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048
bytes
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.490476] UBIFS (ubi0:2): FS size: 99549184 bytes (94 MiB, 784 LEBs), journal size 4952064 bytes (4 Mi
B, 39 LEBs)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.500355] UBIFS (ubi0:2): reserved for root: 4701953 bytes (4591 KiB)
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 18.510575] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 01ED5734-2F14-4D62-9EFE-D78FE977
Thu Feb 29 09:47:40 2024 user.info kernel: [ 18.555164] mount_root: loading kmods from internal overlay
Thu Feb 29 09:47:40 2024 user.info kernel: [ 18.607031] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 user.info kernel: [ 18.615142] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Feb 29 09:47:40 2024 user.info kernel: [ 20.402869] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Thu Feb 29 09:47:40 2024 user.info kernel: [ 20.428056] block: extroot: not configured
Thu Feb 29 09:47:40 2024 user.info kernel: [ 20.440358] mount_root: switching to ubifs overlay
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 20.553659] urandom-seed: Seeding with /etc/urandom.seed
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 22.256587] - preparing events-log partition -
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 22.343664] Unlocking /dev/mtd15 …
Thu Feb 29 09:47:40 2024 kern.notice kernel: [ 22.477616] jffs2: notice: (306) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xd
atum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Thu Feb 29 09:47:40 2024 user.info kernel: [ 22.562784] procd: - early -
Thu Feb 29 09:47:40 2024 user.info kernel: [ 22.563074] procd: - watchdog -
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 23.101366] [01-serial-symlink.sh] New device ttyS0 at /devices/platform/serial8250/tty/ttyS0 appeared!
Thu Feb 29 09:47:40 2024 user.info kernel: [ 23.248604] procd: - watchdog -
Thu Feb 29 09:47:40 2024 user.info kernel: [ 23.256608] procd: - ubus -
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 23.263459] [01-serial-symlink.sh] New device ttyMSM0 at /devices/platform/soc/78af000.serial/tty/ttyMSM0
appeared!
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 23.358825] [01-serial-symlink.sh] New device ttyS1 at /devices/platform/serial8250/tty/ttyS1 appeared!
Thu Feb 29 09:47:40 2024 user.info kernel: [ 23.425348] procd: - init -
Thu Feb 29 09:47:40 2024 user.info kernel: [ 25.872830] urngd: v1.0.2 started.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 25.903783] usb 3-1: new high-speed USB device number 2 using xhci-hcd
Thu Feb 29 09:47:40 2024 user.info kernel: [ 26.490016] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.544243] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.552056] NET: Registered protocol family 15
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.555025] Initializing XFRM netlink socket
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.557948] tun: Universal TUN/TAP device driver, 1.6
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.586984] l2tp_core: L2TP core driver, V2.0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.588616] l2tp_netlink: L2TP netlink interface
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.592570] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.598391] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.602739] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.608223] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.615241] gre: GRE over IPv4 demultiplexor driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.620547] ip_gre: GRE over IPv4 tunneling driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.627904] ip6_gre: GRE over IPv6 tunneling driver
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.705865] tlt-gpio: set names for 1000000.pinctrl chip
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.708241] tlt-gpio: set names for stm32v1 chip
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.734674] hid: raw HID events driver (C) Jiri Kosina
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.737488] GACT probability on
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.740076] Mirror/redirect action on
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.750693] u32 classifier
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.750741] input device check on
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.752319] Actions configured
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.769120] fuse: init (API version 7.32)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 26.785577] PPP generic driver version 2.4.2
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.059401] ess-switch dts node number: 1
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.059555] ess-switch DT exist!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.062442] switch_access_mode: local bus
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.065820] mac mode = 0x0
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.069617] mac mode1 doesn’t exit!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.072214] mac mode2 doesn’t exit!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.075723] ess-uniphy DT doesn’t exist!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.079128] cannot find port_scheduler_resource node
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.083247] qcom,port_phyinfo DT doesn’t exist!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.088283] mdio DT exist!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.092495] switchreg_base_addr: 0xc000000
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.095281] switchreg_size: 0x80000
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.099355] ess-psgmii DT exist!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.102704] current dts led_source_num is 0
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.168302] qca probe malibu phy driver succeeded!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.209773] Initializing DESS!!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.210059] Initializing DESS Done!!
Thu Feb 29 09:47:40 2024 kern.warn kernel: [ 27.211812] qca-ssdk module init succeeded!
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.245204] usbcore: registered new interface driver usbserial_generic
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.245347] usbserial: USB Serial support registered for generic
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.252263] usbcore: registered new interface driver cypress_reconf
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.257030] usbcore: registered new interface driver cypress_serial
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.262893] usbserial: USB Serial support registered for CY7C65213
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.282387] usbcore: registered new interface driver ark3116
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.282548] usbserial: USB Serial support registered for ark3116
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.290566] usbcore: registered new interface driver belkin_sa
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.293308] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.366136] Bluetooth: Core ver 2.22
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.366312] NET: Registered protocol family 31
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.368809] Bluetooth: HCI device and connection manager initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.373086] Bluetooth: HCI socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.379702] Bluetooth: L2CAP socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.384273] Bluetooth: SCO socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.391674] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.394143] Bluetooth: BNEP filters: protocol multicast
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.399667] Bluetooth: BNEP socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.410954] usbcore: registered new interface driver btusb
Thu Feb 29 09:47:40 2024 kern.err kernel: [ 27.412520] Bluetooth: hci0: unexpected event for opcode 0x0000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.413247] usbcore: registered new interface driver cdc_acm
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.415728] Bluetooth: hci0: CSR: Setting up dongle with HCI ver=6 rev=22bb; LMP ver=6 subver=22bb; manufa
cturer=10
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.421167] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.441652] usbcore: registered new interface driver cdc_wdm
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.446675] usbcore: registered new interface driver ch341
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.451267] usbserial: USB Serial support registered for ch341-uart
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.458388] usbcore: registered new interface driver usb_ch343
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.462579] ch343: USB serial driver for ch342/ch343/ch344/ch347/ch9101/ch9102/ch9103/ch9104, etc.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.468525] ch343: V1.5 On 2022.12
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.482186] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.482241] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.490218] usbcore: registered new interface driver cp210x
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.495673] usbserial: USB Serial support registered for cp210x
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.508198] usbcore: registered new interface driver cypress_m8
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.508319] usbserial: USB Serial support registered for DeLorme Earthmate USB
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.513109] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.520465] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.548681] usbcore: registered new interface driver ftdi_sio
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.548818] usbserial: USB Serial support registered for FTDI USB Serial Device
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.555687] Bluetooth: HCI UART driver ver 2.3
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.560539] Bluetooth: HCI UART protocol H4 registered
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.565092] Bluetooth: HCI UART protocol BCSP registered
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.572302] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.575705] Bluetooth: HIDP socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.739739] usbcore: registered new interface driver pl2303
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.739855] usbserial: USB Serial support registered for pl2303
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.750333] PPP MPPE Compression module registered
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.752022] NET: Registered protocol family 24
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.756520] PPTP driver version 0.8.5
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.762747] Bluetooth: RFCOMM TTY layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.763072] Bluetooth: RFCOMM socket layer initialized
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.767892] Bluetooth: RFCOMM ver 1.11
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.780751] usbcore: registered new interface driver usblp
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.838523] xt_time: kernel timezone is -0000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 27.906621] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.212016] usbcore: registered new interface driver option
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.212150] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.217131] option 3-1:1.0: GSM modem (1-port) converter detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.223619] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.230067] option 3-1:1.1: GSM modem (1-port) converter detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.236779] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.242852] option 3-1:1.2: GSM modem (1-port) converter detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.249647] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.255718] option 3-1:1.3: GSM modem (1-port) converter detected
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.262443] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 28.284588] [01-serial-symlink.sh] New device ttyUSB0 at /devices/platform/soc/60f8800.usb2/6000000.dwc3/x
hci-hcd.1.auto/usb3/3-1/3-1:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.287033] qmi_wwan 3-1:1.4: cdc-wdm0: USB WDM device
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.300201] qmi_wwan 3-1:1.4 wwan0: register ‘qmi_wwan’ at usb-xhci-hcd.1.auto-1, WWAN/QMI device, de:62:a
7:8c:c7:a1
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.303979] usbcore: registered new interface driver qmi_wwan
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.318829] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 28.319910] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 28.461773] [01-serial-symlink.sh] New device ttyUSB1 at /devices/platform/soc/60f8800.usb2/6000000.dwc3/x
hci-hcd.1.auto/usb3/3-1/3-1:1.1/ttyUSB1/tty/ttyUSB1 appeared!
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 28.671930] [01-serial-symlink.sh] New device ttyUSB2 at /devices/platform/soc/60f8800.usb2/6000000.dwc3/x
hci-hcd.1.auto/usb3/3-1/3-1:1.2/ttyUSB2/tty/ttyUSB2 appeared!
Thu Feb 29 09:47:40 2024 user.warn kernel: [ 28.868225] [01-serial-symlink.sh] New device ttyUSB3 at /devices/platform/soc/60f8800.usb2/6000000.dwc3/x
hci-hcd.1.auto/usb3/3-1/3-1:1.3/ttyUSB3/tty/ttyUSB3 appeared!
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 30.187042] ath10k_ahb a000000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 30.187110] ath10k_ahb a000000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 30.200040] ath10k_ahb a000000.wifi: firmware ver 10.4-3.53-00050 api 5 features no-p2p,mfp,peer-flow-ctrl
,btcoex-param,allows-mesh-bcast,no-ps crc32 de6451a8
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 30.251871] ath10k_ahb a000000.wifi: board_file api 2 bmi_id 0:16 crc32 01911547
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 31.638735] ath10k_ahb a000000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 512 raw 0 hwcr
ypto 1
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699458] ath: EEPROM regdomain: 0x0
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699476] ath: EEPROM indicates default country code should be used
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699481] ath: doing EEPROM country->regdmn map search
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699493] ath: country maps to regdmn code: 0x3a
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699501] ath: Country alpha2 being used: US
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 31.699506] ath: Regpair used: 0x3a
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 32.602516] ath10k_ahb a800000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 32.602714] ath10k_ahb a800000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 32.615786] ath10k_ahb a800000.wifi: firmware ver 10.4-3.53-00050 api 5 features no-p2p,mfp,peer-flow-ctrl
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 32.660039] ath10k_ahb a800000.wifi: board_file api 2 bmi_id 0:17 crc32 01911547
Thu Feb 29 09:47:40 2024 kern.info kernel: [ 34.045923] ath10k_ahb a800000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 512 raw 0 hwcr
ypto 1
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106934] ath: EEPROM regdomain: 0x0
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106955] ath: EEPROM indicates default country code should be used
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106964] ath: doing EEPROM country->regdmn map search
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106978] ath: country maps to regdmn code: 0x3a
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106988] ath: Country alpha2 being used: US
Thu Feb 29 09:47:40 2024 kern.debug kernel: [ 34.106996] ath: Regpair used: 0x3a
Thu Feb 29 09:47:40 2024 user.info kernel: [ 34.111233] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Feb 29 09:47:41 2024 daemon.notice procd: /etc/rc.d/S06firewall: uci: Entry not found
Thu Feb 29 09:47:41 2024 daemon.notice procd: /etc/rc.d/S06firewall: sh: 1: unknown operand
Thu Feb 29 09:47:41 2024 daemon.notice procd: /etc/rc.d/S06firewall: sh: 0: unknown operand
Thu Feb 29 09:47:41 2024 daemon.notice procd: /etc/rc.d/S06firewall: UCI configuration was not found for HNAT.
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: bonding
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: 8021ad
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: 8021q
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: macvlan
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: veth
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: bridge
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: Network device
Thu Feb 29 09:47:43 2024 user.notice : Added device handler type: tunnel
Thu Feb 29 09:47:43 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Feb 29 09:47:43 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Feb 29 09:47:44 2024 daemon.info dnsmasq[1761]: Connected to system UBus
Thu Feb 29 09:47:44 2024 daemon.info dnsmasq[1761]: started, version 2.85 cachesize 150
It appears from the logread that the SIM card might not be inserted, as there are no regular signs of its presence. Could you provide details about the firmware update you performed, including the version you updated from and the version you updated to? Additionally, would you be willing to downgrade your firmware to the previous version to verify if the SIM card works with it?
Marijus
