Shared Wireless connection throught LAN
I have a RUT241. I connect the RUT241 to a WIFI hotspot and I would like to share the Wireless connection throught the LAN port.
I find that documentation:
https://wiki.teltonika-networks.com/view/Connecting_to_a_Hotspot_WiFi_for_Internet_Connectivity
I think I should activate the “Redirect captive portal” option. I don’t see that option.
Is there any option, I forget to set ?
Best regards
Hello @xavier,
Could you confirm if the TravelMate package is installed on your device, as mentioned in the Prerequisites section of the example?
I indeed forget to install the package. I install it and I apply the “Redirect captive portal” option but the BSSID doesn’t seem to be set ( it stay at 00:00:00:00:00)
I try to do the same with my Smartphone share connection. With that connection, it seems to work and my computer on LAN have web connection.
