Shaping Modbus Client Data
We would like to shape Modbus Client data before we send it to Data_to server.
Mainly we would like to apply scaling and potentially add units to the data before we sent it to server.
Is there a way to do this?
Unfortunately, such functionality is not available.
If this is necessary, you could try to find a workaround. For example, create a script on your RUT device that will send Modbus requests to your Modbus servers (slaves) periodically via crontabs. You can find the Modbus CLI commands here. Then, process the data as you need within your script and put this data into custom Modbus registers on the RUT device. Afterwards, read the data from custom registers via Modbus and send it to your server using data to server functionality. In this case, this is just a suggestion. If you decide to do this, you will need to write the scripts yourself.
