Setting up RUT956 Wifi to Lan port
I would like to use an existing WIFI on site to connect the RUT956 router. Once connected I would like to use the LAN ports to connect my cameras to the existing network.
In your case, using Relayd package would likely be the best option, as you would avoid having to setup routing, and all of your devices would remain on the same network. Instructions on how to configure Relayd can be found here: Relayd RutOS - Teltonika Networks Wiki
Let me know if you encounter any issues.
