Setting up MQTT on RUT241
Hello dear support team!
We would like to configure a Teltonika RUT241 as an MQTT client for a remote monitoring project.
Currently, we are successfully using Modbus Serial Client + Data to Server (HTTP) to collect data from PLCs and send it to our backend.
Now we want to switch (or extend) this setup to MQTT.
Goal (Phase 1 – Testing)
  • Use RUT241 as an MQTT client
  • Send Modbus data to a public test broker (e.g. HiveMQ)
  • Later switch to our own Mosquitto broker on a Windows server
Our questions
  1. What is the minimum configuration required on RUT241 to:
    • Read data from Modbus (already working)
    • Publish this data via MQTT to a broker?
  2. Which services/components should be used?
    • MQTT Publisher?
    • Data to Server with MQTT?
    • Modbus + MQTT integration (if available)?
  3. What is the simplest recommended architecture on the router side?
    (We noticed many MQTT-related options/packages and would like to avoid unnecessary complexity.)
Important note
We do NOT want to mix HTTP and MQTT in this setup.
We only want a clean MQTT-based data flow:
Modbus → MQTT → Broker
A minimal working example/configuration would be highly appreciated.
Thank you!
