I hope you are doing well. I am sending a GPRS command setdigout 11 (I need to set both outputs as 1). I Created the Codec 12 Command for this. setdigout 11 = 0000000000000014OC01050000000C7365746469676F7574203131010000F196 (00000000 00000014 OC 01 05 0000000C 7365746469676F7574203131 01 0000F196)
For the same device getio(000000000000000D0C010500000005676574696F01000000CB) and getver(000000000000000E0C010500000006676574766572010000A4C2) using same protocols working fine.
Please check out Setdigout 11 command bytes and advise accordingly.
I have tested the following Commands. It’s working fine in communication while the response from the device for command is setdigout 11 00000000000000140C01050000000C7365746469676F7574203131010000BED5
