Seeking advice/experiences: Expanding IoT network with RUT955 and TAP100
Hello community,
I am currently running a reliable IoT network based on a Teltonika RUT955. I need to extend the Wi-Fi coverage for my IoT devices by adding 1 or 2 TAP100 access points.
Initially, I stumbled upon this official guide for a wireless mesh configuration: teltonika-networks.com. However, if I understand correctly, this native 802.11s mesh setup is not supported on my RUT955 because it is stuck on the legacy firmware branch (00.06.xx) and didn’t receive the newer RutOS updates.
Since the TAP100s will be connected via LAN cables to the RUT955, I am looking for your real-world experiences and recommendations on how to set this up effectively for an IoT environment.
  1. Has anyone implemented a similar setup using the RUT955 as the main gateway and TAP100s as wired access points with identical SSIDs for simple client roaming? How stable does it perform with IoT sensors?
  2. Are there any specific pitfalls regarding VLANs, DHCP management, or firewall zones on the older 00.06.xx firmware when connecting newer APs like the TAP100?
  3. Would you recommend any alternative architectures or workarounds without upgrading the main router?
I would highly appreciate any insights, configuration tips, or shared experiences from anyone who has a similar setup running.
Thanks in advance!
A wired setup with the same SSID and security settings sounds like a sensible approach for IoT coverage. I’d keep DHCP centralized on the RUT955 and verify VLAN compatibility first. Have you tested whether your IoT devices roam reliably between the TAP100 access points?
Thanks for the feedback! To clarify: I don’t actually own the TAP100 yet, I am currently in the planning phase for this setup.
Your point about IoT roaming is spot on. Since most cheap IoT chipsets (like ESP8266/ESP32) are notorious “sticky clients” and don’t support 802.11k/v/r, relying on seamless roaming is usually a gamble.
Is there someone how have a setup like this and experiance.
Hello @yustbeyourself!
As mentioned in the forum, a wired solution is the most optimal choice. To ensure optimal performance across multiple TAP100 access points, a wired connection with a PoE switch or PoE injectors is recommended. In a wireless mesh network, a portion of the Wi-Fi bandwidth is consumed solely for inter-node communication, which reduces overall network throughput. A wired network powered via PoE delivers maximum stability, minimal latency, and full available data capacity.
Additionally, you can configure a Minimum RSSI threshold on the TAP100 access points to forcefully disconnect IoT devices with weak signals. This effectively solves the ‘sticky client’ issue and ensures smooth roaming.
Hope this helps.
L.
