Hi, so I am trying to test writing a custom appliaction on a RUT, I have several but for this test I am using the most recent SDK for a RUT240. I have a fresh install of Ubuntu18 as recommended. I am able to create and compile the following code on Ubuntu
#include <stdio.h>
int main(void)
printf("\nHello, world!\n\n");
return 0;
This is saved in
~/RUTX_R/rutos-ath79-rut2-gpl/helloworld
I have followed the instructions from OpenWrt https://openwrt.org/docs/guide-developer/helloworld/chapter2
I have created a Makefile
shown below and saved it to
/RUTX_R/rutos-ath79-rut2-gpl/mypackages/examples/helloworld
as per the instructions, then I have tried to register the package
in feeds.conf.default, there are some repos pointed to already there
src-link mypackages ~/RUTX_R/rutos-ath79-rut2-gpl/mypackages
src-git packages https://git.openwrt.org/feed/packages.git^65057dcbb5de371503c9159de3d45824bec482e0
src-git luci https://git.openwrt.org/project/luci.git^3b3c2e5f9f82372df8ff01ac65668be47690dcd5
src-git routing https://git.openwrt.org/feed/routing.git^c30c9ffc93702365439a7647244a052531f2e957
src-git telephony https://git.openwrt.org/feed/telephony.git^7f73a9ad19269dcddcb7fc26e03a9823717587bb
I update and install the feeds, (there are no errors) using
./scripts/feeds update mypackages
./scripts/feeds install -a -p mypackages
But when I run make menuconfig
I don’t see any reference to my ‘hello world’ application?
I think I am having a problem with the feed/packages and perhaps I am adding the src-link
to the wrong file?
Any help would be great!
MAKEFILE:
include $(TOPDIR)/rules.mk
# Name, version and release number
# The name and version of your package are used to define the variable to point to the build directory of your package: $(PKG_BUILD_DIR)
PKG_NAME:=helloworld
PKG_VERSION:=1.0
PKG_RELEASE:=1
# Source settings (i.e. where to find the source codes)
# This is a custom variable, used below
SOURCE_DIR:=~/RUTX_R/rutos-ath79-rut2-gpl/helloworld
include $(INCLUDE_DIR)/package.mk
# Package definition; instructs on how and where our package will appear in the overall configuration menu ('make menuconfig')
define Package/helloworld
SECTION:=examples
CATEGORY:=Examples
TITLE:=Hello, World!
endef
# Package description; a more verbose description on what our package does
define Package/helloworld/description
A simple "Hello, world!" -application.
endef
# Package preparation instructions; create the build directory and copy the source code.
# The last command is necessary to ensure our preparation instructions remain compatible with the patching system.
define Build/Prepare
mkdir -p $(PKG_BUILD_DIR)
cp $(SOURCE_DIR)/* $(PKG_BUILD_DIR)
$(Build/Patch)
endef
# Package build instructions; invoke the target-specific compiler to first compile the source file, and then to link the file into the final executable
define Build/Compile
$(TARGET_CC) $(TARGET_CFLAGS) -o $(PKG_BUILD_DIR)/helloworld.o -c $(PKG_BUILD_DIR)/helloworld.c
$(TARGET_CC) $(TARGET_LDFLAGS) -o $(PKG_BUILD_DIR)/$1 $(PKG_BUILD_DIR)/helloworld.o
endef
# Package install instructions; create a directory inside the package to hold our executable, and then copy the executable we built previously into the folder
define Package/helloworld/install
$(INSTALL_DIR) $(1)/usr/bin
$(INSTALL_BIN) $(PKG_BUILD_DIR)/helloworld $(1)/usr/bin
endef
# This command is always the last, it uses the definitions and variables we give above in order to get the job done
$(eval $(call BuildPackage,helloworld))
