SDK build error Coova Chilli libgsm.h (RUT300 7.6.10)
Hi. How to overcome build error when compiling SDK RUT30X_R_GPL_00.07.06.10?
The error is for Coova Chilli (included file libgsm.h cannot be not found). Make menuconfig does not allow you to REMOVE “Coova Chilli”, only include it or leave it as optional.
I performed a clean install of Ubuntu 20.04 LTS, along with Node and NPM, and the required packages as per the README file. Sadly this did not solve the issue.
make[6]: Entering directory '/home/user/RUT30X_R_GPL_00.07.06.10/rutos-ath79-rut30x-gpl/build_dir/target-mips_24kc_musl/***coova-chilli-2.12.1***>
make[7]: Entering directory '/home/user/RUT30X_R_GPL_00.07.06.10/rutos-ath79-rut30x-gpl/build_dir/target-mips_24kc_musl/coova-chilli-2.12.1>
depbase=`echo chilli.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/bash ../libtool  --tag=CC   --mode=compile mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I../json   -I/home/user/RUT30X_R_GPL_>
mv -f $depbase.Tpo $depbase.Plo
OpenWrt-libtool: compile:  mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I../json -I/home/user/RUT30X_R_GPL_00.07.06.10/rutos-ath79>
In file included from chilli.h:44,
                 from chilli.c:22:
***gsm.h:5:10: fatal error: libgsm.h: No such file or directory***
 #include <libgsm.h>
compilation terminated.
To compare, if I download the same version SDK (7.06.10) for the TRB140, it builds without any problem. Perhaps the Teltonika team have not fully tested the scripts for the RUT300?
