Scan Networks Rut956 #2
I had reported a problem here (same heading), after 15 days the post is closed. I was told that it was possibly a software error and that the problem was being checked. Unfortunately I have not yet received an answer.
As mentioned in the previous thread, I confirm that there is a firmware issue. It is currently being addressed and will be resolved in the upcoming firmware releases.
Marijus
Hello Marijus,
can I use an older firmeware until the new firmeware is released, or is the same error to be expected here as well.
Thomas
Hello @thhenschel,
I’ve tested Firmware version 07.05.4, and it’s working as expected.
Marijus
I have tested version 07.05.4, same error. Could it be that searching for a wifi network only works if the router is connected by cable?
You should be able to access it without a cable. It might take some time for the new wireless access point to be added.
Alternatively, you can try connecting via a LAN cable to access your router and then scan for wireless networks. This should definitely work.
Marijus
