RUTX50 Zerotier Drops out
I have an RUTX50 patched with the latest firmware.
I connect it to a ZeroTier network using the instructions found here
https://wiki.teltonika-networks.com/view/ZeroTier_Configuration
The only difference being my LAN is 192.168.0.0/24
It works perfectly and does exactly what I need.
Unfortunately, the RUTX always drops off the ZeroTier network after a 1 or 2 days and I have to go in the the RUTX admin and disable and then re-enable the ZeroTier VPN.
Devices on the LAN usnig zerotier clients remain connected. It is just the RUTX50 that drops.
I need this to work so that I can access docker containers on the LAN that cannot run zerotier clients.
How can I stop the RUTX from dropping off?
This sounds like the same problem I have, it happens in my case only after an update to the latest FW, it was all Ok before going to 7.05.4
