Hi, I bought a rutx50, I understand that these routers should never be turned on without the antennas plugged in. I don’t need the GPS though. Can I use it without the GPS antenna inserted? Thank you
Yes, you can absolutely use the RUTX50 without the GPS antenna connected if you don’t need GPS services. Additionally, it’s safe to turn on your router without any antennas connected and attach them afterward. This will not cause any issues with the device.
