RUTX50 with Iskra P-60. Roof mounting, port selection and base station selection
I started using RUTX50 a couple of months ago with Iskra P-60 antennas. I am trying to find the best base station with the best combination of Stability/Bandwidth/Latency on my 4G connection.
I rigged a setup to monitor RSRP,RSRQ,SINR,RSSI, ICMP response time and loss with 3min logging interval. Have had that up and running a couple of days now. Need to do some adjustments to my mast pipe mount before I can start adjusting the bearing and height with proper accuracy to be able to return to the best adjustment later. However before starting I wanted to share my setup and thoughts, so if someone feel the need to give feedback, that is appriciated.
I have a couple base stations to try:
BS 4G Band Distance [km] Line of sight estimation
A 20,3 3,6 40% over sea, 60 % treetops
B 20,3,1 6,2 25% over sea, 60% treetop, 15 % forest on hill
C 20,3,1,7 8,6 50% over sea, 50 % treetops
D 20,3 8,0 90% over sea, 10% treetops
E 20,3 11,4 Free line of sight
4G Band Downlink Uplink Wavelength WL*2
b7 2 675 MHz 2 555 MHz 11,73 cm 23,47 cm
b1 2 120 MHz 1 930 MHz 15,53 cm 31,07 cm
b3 1 867,5 MHz 1 772,5 MHz 16,91 cm 33,83 cm
b20 816 MHz 857 MHz 36,74 cm 73,48 cm
Before my RUTX50 I was running RUT241 with a QuSpot omni-directional antenna. I was not pleased with connection, so decided to upgrade to a more robust and futureproof setup. However with that setup I noticed that it mostly connected to cells in towers A,D,E. Even if the distance is much greater to D&E. With RUTX50 and Iskra antennas installed I have only tried D since I wanted to get my logging up and running before started tweaking.
My next step will be to rise the antenna higher and direct it towards BS A.
Currently I have the antennas mounted horizontally on one pipe mast. The first pair (Higher mount) connected to port 1&3 from the left. The second (lower mount) connected to 2&4 on my RUTX50.
antennas_on_roof
According to Antenna distance in one pair of iskra P-56, I assume same goes for P-60.
If I use base station A, that uses b20,b3. I aim to make distance of higher pair suitable to b3 and lower pair according to b20. That would give x1=34cm & x2=74cm.
  1. Is there a preferred minimum distance y between antenna pairs?
  2. Is there a preferred minimum distance z from antennas to metal roof?
  3. Is there an preferences how to connect the pairs to RUTX50.
I intend to start with trying these combinations. If someone believe there are better ones please tell.
RUTX50 port Combination 1 Combination 2
1 b3 high antenna (pair 1) b3 high antenna (pair 1)
2 b20 high antenna (pair 2) b3 low antenna (pair 1)
3 b3 low antenna (pair 1) b20 high antenna (pair 2)
4 b20 low antenna (pair 2) b20 low antenna (pair 2)
Regarding antenna installation I saw a thread here in the community where someone had mounted the same iskra P-60 antennas in rectangular mounting instead as vertically on one pipe. Are there any perks for this type of mounting instead of getting both pairs as high as possible?
Lastly sharing a couple of pictures of my current readings before I start moving the antennas. Of course I get one of the best results so far in speedtest now. This last 6 months it has been around 2-40 down, 15 up with ping about 70-90.
Makes sense to go for base station A at a distance of 3.6km.
However, if the trees are closer to the BS than they are to you, you’ll have to raise the antennas a very long way to get any additional benefit, so high they may interfere with air traffic!!! wouldn’t want to bring down an aeroplane!!!
If the trees are closer to you, very close, you might have a chance. Rather than moving the antennas upwardly, can you move them sideways to avoid the trees?
My only other thought would be that trying to fix yourself to a specific BS can in itself be problematic if it becomes congested with users, goes offline for whatever reason, etc.
Can you point the antennas at a group of BS’s within a fairly narrow angle of view so that your connection can freely move to one and another.
I’m guessing you must live on an offshore island or at the end of a peninsular or on a headland!?
