RUTX50 WiFi not working
Hello, I have been using a RUTX50 for a few months now, and it has been working very well. However, I recently changed the antenna to a Poynting MIMO 7, and now I am not able to access Wi-Fi. Could you please provide some insight into why this might be happening?
You should check the antenna’s integrity itself to ensure that wires and other parts are not damaged. Also, make sure the antenna itself is screwed on tightly and correctly, as this seems to be entirely an antenna issue.
Marijus
