my RUTX50 (bought June 2026, HW version 0303, batch 036, firmware RUTX_R_00.07.25.3 stable, modem RG501Q-EU) shows several serious faults. A warranty claim with the reseller is open, but I would like to know whether this is a known issue and whether it is hardware or firmware related.
SETUP
Caravan. Wi-Fi client (Multi AP) on radio0 / 2.4 GHz as WAN uplink (Starlink Wi-Fi, home Wi-Fi, campsite Wi-Fi), mobile as failover via mwan3, an access point on the same radio, 5 GHz AP on fixed channel 36. WireGuard, GPS/AVL and Data to Server (MQTT) in use. 12 V supply.
Wi-Fi client stops getting frames through (recurring)
Signal is good (-40 to -60 dBm), but authentication requests time out at all access points (“send auth … try 1/3 … 3/3”, “authentication … timed out”), or, when connected, the gateway no longer answers ARP. Other devices on the same Wi-Fi keep working. Sometimes “wifi up radio0” helps, sometimes only a reboot.
Kernel: “ath10k_ahb a000000.wifi: could not get mac80211 beacon”, “peer-unmap-event: unknown peer id”.
Incidents: 18.10. (twice), 23.10., 28.10., 29.10.2026.
Looks like the same issue as here: community.teltonika.lt/t/rutx50-recurring-oom-events-and-excessive-slab-unreclaimable-growth/19577 -
Modem disappears from the USB bus
On 31.10.2026 at about 09:02, with the router running for almost two days without reboot or power loss, the modem vanished completely: lsusb shows only the root hubs, /dev/ttyUSB* are gone, gsmctl returns “Failed to handle AT exec. ERR: Not found”. Mobile and GNSS were down for about 77 hours until the next reboot. The same happened on 07.10.2026 (see 3). -
Filesystem damage
- 07.10.2026: router did not boot normally (overlay read-only, “uci: I/O error”, many SQUASHFS errors, modem missing, boot loop). Recovered via bootloader and full reconfiguration. A full reconfiguration was already necessary in mid-July 2026.
- 31.10.2026, 09:05 (3 minutes after the modem disappeared): /log/log.db got corrupted, kernel shows “jffs2: Node CRC c42a1ff5 != calculated CRC c9175330 for node at 000544b0”, logd loops “Failed to restore database”.
Kernel panic
On 03.11.2026, while generating the troubleshoot file via WebUI, the kernel crashed (pstore/ramoops):
Unable to handle kernel paging request at virtual address 378fe3fc when read
Internal error: Oops: 5 [#1] SMP ARM
PC is at __kmem_cache_alloc_node+0xcc/0x4bc
… __alloc_skb … skb_segment … tcp_gso_segment … wg_xmit [wireguard]
Kernel panic - not syncing: Fatal exception in interrupt
Before the crash the 5 GHz radio logged “ath10k_ahb a800000.wifi: failed to send pdev bss chan info request” more than 1,000 times within about two hours. The troubleshoot file could not be created. After the reboot the modem was back. -
WireGuard
After a change of the home public IP (DynDNS endpoint) the tunnel is not re-established automatically, although persistent keepalive is set and wireguard_watchdog runs every minute.
QUESTIONS
- Are these issues known? Does the combination (modem lost on USB, jffs2 CRC errors, slab corruption / kernel panic) point to a hardware defect (RAM, flash, power) of this unit?
- Is there a fix or test firmware for the ath10k Wi-Fi client issue? Would 00.07.26 help?
- Does the current hardware revision behave differently?
I can provide the full kernel log, the ramoops crash dump, logread and a configuration export (passwords removed) privately.
Thank you!
