RUTX50 VRRP - IPSec
Hello!
I’m planning to install a pair of RUTX50 in VRRP cluster. I need to run IPsec on them to connect to my HQ. My problem is, that at the same time it only one of the RUTX should connect tothe remote endpoint (HQ). Actually I’m trying to play with a custom bash script what are monitoring VIPs with IP monitor but it’s not reliable 100%. Are there any official solution to make a VRRP cluster from RUTs and run some VPN service too?
Thank you for the help.
Officially, this is not something that we have a toggle or an option for, so using custom scripts would be the only way to achieve this. I may propose that this be implemented for our R&D so they would consider this in future releases.
