RUTX50 VPN traffic
Hello, I have a RUTX50 which connects to a Fortigate via IPSEC. The problem is that i cannot ping or reach anything that is in the RUTX lan so I am guessing it has something to do with firewall setup.
The config is something like this.
rutx lan - rutx - internet - fortigate - fgt lan
I can ping from the rutx lan the fgt lan, but not the other way around. Thank you.
When configuring IPsec, ensure that the “Local subnet” is set correctly, as this is one of the most common issues that can interfere with LAN network connections. Additionally, on FortiGate, double-check that the “Remote subnet” is configured correctly as well.
