RUTX50 trigger APN change over SMS
Hello everyone!
I would like to send SMS command to the modem and trigger APN “profile” switch. Profile is in quotes because there aren’t any as option.
I have two APN profiles, one is for fast low latency internet and other is for slower internet but with static IP. Same card, same number, just different APN.
Is there a way to do that. I did not install SDK yet and I hope it can be done without modifying anything - with stock firmware.
In either case any pointers will help!
Thank you in advance
If you have, for example, two profiles: default and profile2
You can change between them using Mobile Utilities. Send SMS to router:
<router's password> pr <profile name>
Passwd148* pr default
or
Passwd148* pr profile2
FW version: 7.08.2
Works. THX!
