Rutx50 speed problem
Hello.
My Rutx50 doing following. If I test speed inside the router then its 500 and if i use Speedtest app then its about 5-20.
Anybody knows where is the problem. Why it cut off 95%.
Thank you.
Thanks for the query.
What is the FW of your device? Can you please upgrade to 07.09 and check if its still the case? You can FW upgrade your device from the WebUI, System > Firmware section.
Please let me know about the result!
Caner
It is 07.09
And the modem’s firmware, is that up to date too?
What type of device is the speed app installed on?
Is the device connected via WiFi or via an ethernet cable?
Hi.
I did some testing and result is following.
Through the Wifi the speed is very low. On the cable the speed is super.
If I connect another wifi router by cable to Teltonica the problem is same. Wifi is low and via cable is all ok.
I tested 3 differnt routers. Same problem.
This is normal, a WiFi connection is always slower and can be problematic at times.
Wireless connectivity is excellent, but it does have its problems and limitations.
What is the wireless device and how old is it?
Older devices are slower and as such have compatibility issues with modern technology. (Old device to new router).
When a device connects to a router the two devices negotiate a speed that best suits both, your device may not be capable of high speed connectivity.
