I have a RUTX50 installed on my caravan connected to a Poytning MIMO-3-15 for (both LTE and Wifi antennas) - (Yes I’m aware the Poytning only has 2 LTE antennas and the RUTX50 should have 4 LTE antennas).
My LTE performance is OK - my getting 227/18 Mbps from a Speedtest from on the router at my current location.
However the Wifi performance is poor. I’m running iperf3 on the rutx50 and from a couple of different client machine 10 metres away from the caravan I’m getting about 7 Mbps on 2.4 Ghz wifi. On 5 Ghz wifi I get about 15 Mbps.
As a comparison if I plug in the client directly to the router via a LAN cable I get 800-900 Mbps.
I have split my Wifi into 2.4Ghz and 5Ghz.
For the 2.4Ghz I have the radio set to:
Mode N
Channel Auto
Width 20 Mhz
Transmit Power 100%
Allow legacy 802.11b rates - on
For the 5Ghz I have the radio set to:
Mode AC
Channel Auto
Width 20 Mhz
Transmit Power 100%
Other settings are blank/default.
Any thoughts suggestions on improving the wifi performance?
Jason
