RUTX50 router + Poynting OMNI-214 antenna
Hi
I have a RUTX50 router + Poynting OMNI-214 antenna. The OMNI-214 antenna’s cables are marked with cell 1 and 2 and main and aux. The RUTX50 simply state mobile on the ports. Does it matter in which mobile ports I connect each cable?
With an omni antenna the order is not likely to make a huge diff. Try “main” and “aux” to 0 and 3 and “cell 1” and “cell 2” to 1 and 2. Run speed test. Swap connections. Run speed test again. Whatever works better - keep that.
