RUTX50 profiles not switching
Good day, i have setup one profile to run from 3-6AM. The problem now is that it doesn’t work, it doesn’t switch always, and if it does it doesn’t go back to default one after 6AM. Am i doing something wrong? Am i missing something? I have RUTX50 with latest firmware installed.
Hi mvstkraw,
Kindly make sure that NTP and Scheduler is properly configured.
NTP
Scheduler
Let me know if this helps.
Hi, yes everything is enabled. Do i have to check anything else than “Enable NTP client” or …?
