I want to plug my rutx50 directly to my 12v setup in my campervan.
I’m trying to understand why I could not use the PR2FK20M with a 2amp fuse. Sorry I’m not familiar with complex electrical topics and when I read the power instructions I don’t understand.
I’ve seen a post where Marjus adviced to use the PR2AM20M but it was long time ago.
So my question is : should i use PR2AM20M to use 12v to not use the 220v cable?
Thank you for your help and sorry English is not my primary language.
The PR2FK20M and PR2PL15B would both work in this setup with a 2A fuse. I recommend following the approach described here: Ignition detection solution - Teltonika Networks Wiki. You can use either of the two mentioned cables. Adding a TVS diode would also be beneficial.
As Marius mentioned, the PR2AM20M is another suitable option.
