RUTX50 port forwarding from public IP address
Now with HTTPS and DNS (public address) working I tried to access one of my ports on LAN from WAN. It doesn’t work. I get reply “unexpectedly closed the connection.”
Earlier, before secure HTTPS it worked perfect to access LAN ports from WAN.
Regards, Jaan
Thank you for reaching out.
To investigate this issue in more depth, we’ll need to contact you privately. For that, I’ve sent you a form to fill out. When completing it, please use 12226 as the ticket ID. Once submitted, we’ll reach out to you privately with the necessary information requested.
