RUTx50 physical eth2 and eth3 activation
I have just received my RUTx50 and try to use physical port marked LAN3 and 4.
Should those be on linux-level eth2 and eth3 if activated ?
Using ifconfig command I can see only eth0 and eth1 after I created LAN1 and attach eth1 to it.
I cant find a way to activate eth2 or eth3 with webUI …
Running RUTX_R_00.07.09.1
Br
-Ville
Atach all ports to ETH0 same bridge in lan physical and work. all lan ports.
They should all function perfectly ‘out of the box’ or after doing a factory reset i.e. using the default settings.
If you think you may have altered the default port settings, then there are two things to check.
First, on the Web UI, go to NETWORK > LAN > LAN INTERFACES:lan and click on ‘Edit’. Next, select the ‘Physical Settings’ tab and you settings should be the same as the screen below - eth0
Second, on the Web UI, go to NETWORK > PORTS > PORT SEETTINGS and click on ‘Sellect all’ and then the ‘Edit ports’ button. You will have more ports than my exxample, because I’m taking these screen shots off a RUTX09.
The dialogue shown below will open and just make sure all advertisement options are checked.
Thanks guys !!
My first idea was that every eth-port have independent addresses as linux-servers, but if bridge is needed with this I can always add seconday addresses to related bridge… in routing perspective its all the same.
Br
-Ville
