RUTX50 modem connection lost every ~15-30 minutes
Hello
Firmware version
RUTX_R_00.07.06.3
Firmware build date
2024-01-12 16:47:21
Internal modem firmware version
RG501QEUAAR12A08M4G_04.200.04.200
Kernel version
5.10.199
Wed Feb 7 17:21:20 2024 daemon.notice netifd: mob1s1a1 (8572): Mobile connection lost!
Wed Feb 7 17:21:20 2024 daemon.notice netifd: Interface ‘mob1s1a1’ has lost the connection
Wed Feb 7 17:21:20 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Wed Feb 7 17:21:20 2024 daemon.notice netifd: mob1s1a1 (13068): Stopping network mob1s1a1
Wed Feb 7 17:21:20 2024 daemon.notice netifd: Network device ‘qmimux0’ link is down
Wed Feb 7 17:21:20 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Wed Feb 7 17:21:20 2024 daemon.notice netifd: mob1s1a1 (13068): Stopping network on /dev/cdc-wdm0!
Wed Feb 7 17:21:20 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Wed Feb 7 17:21:20 2024 daemon.notice netifd: mob1s1a1_4 (8589): udhcpc: SIOCGIFINDEX: No such device
Wed Feb 7 17:21:20 2024 daemon.notice netifd: mob1s1a1_4 (8589): udhcpc: received SIGTERM
Wed Feb 7 17:21:20 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Wed Feb 7 17:21:20 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Any ideas why?
p.s. already tried everything - manual GSM operator + static LTE channel (B3) etc.
Next to it is RUT360 with same GSM operator sim card on the same channel - works without any issues.
Thank you for reaching out!
Could you provide some logs before the disconnection? They could be helpful in determining the reason of the disconnection.
Additionally, could you clarify if on the RUT360 you’re connecting to the same band with the same APN settings?
Before disconnect :
Thu Feb 8 08:47:50 2024 kern.info Joined LTE network (internal modem)
Thu Feb 8 08:47:50 2024 kern.info Connected to LV TELE2 Zelta Zivtina operator (internal modem)
Thu Feb 8 08:48:19 2024 kern.warn kernel: [1718647.175877] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 08:51:46 2024 kern.warn kernel: [1718853.816777] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 08:53:50 2024 kern.warn kernel: [1718977.415773] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 08:53:52 2024 kern.warn kernel: [1718979.360381] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 08:55:06 2024 kern.warn kernel: [1719053.908023] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 08:56:06 2024 kern.warn kernel: [1719113.913641] ath10k_ahb a800000.wifi: Invalid VHT
Thu Feb 8 09:09:30 2024 kern.warn kernel: [1719917.448095] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 09:10:03 2024 kern.warn kernel: [1719950.828657] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 09:10:45 2024 kern.warn kernel: [1719993.121443] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 09:15:47 2024 kern.warn kernel: [1720295.200050] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 09:16:22 2024 kern.warn kernel: [1720329.812843] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Thu Feb 8 09:19:38 2024 daemon.notice netifd: mob1s1a1 (5937): Mobile connection lost!
Thu Feb 8 09:19:38 2024 daemon.notice netifd: Interface ‘mob1s1a1’ has lost the connection
Regarding RUT360 - same band, same APN (auto apn on and they have same APN)
Regarding this RUTX50 with issues - mobile interface is a fallback on this box, main WAN is Ethernet.
Can it be related somehow?
I’m not sure why and how but seems that problem is solved - modem was stable last 24h.
Maybe GSM operator did something, maybe interference near by, don’t know.
In case the issue repeats again, collect a troubleshoot file by navigating to System → Maintenance → Troubleshoot and inform me. I will send you the instructions to get in contact with us directly.
