Rutx50 limited upload
I have a Telenor simcard and I its unlimited but i cant increas upload speed. I did speed test and its limited to 50-60mbps, why? I didnt limit anything. Most probably settings are on default.
I want to live stream 4 cameras 4k videos without lagg. Anything?
Which firmware version is your RUTX50 running on?
Make sure it’s 07.07.1.
Then paste a screenshot of your mobile connection status from here please:
Ok, first i upload ed wrong picture. Now is the one more or less correct. Mostly its around 50-60 as mentioned.
I just went of working nights, but i will provide you with picture. I have 4G/5G but im unsire about firmware. Will be back after some hours. :slight_smile:
I was just wondering as per your screenshot your upload/download speeds look quite nicely?
Which speeds were you expecting?
You might have an asymmetric internet connection. Not all internet plans are the same—some offer higher download speeds, others provide higher upload speeds, and some have equal speeds for both. To understand what you should expect for your download and upload speeds, please contact your internet provider.
If upload speed is important to you, you can test it by manually allowing or banning certain bands in the router.
For example when I allow only band B3 and B1 in RUTX50, then my upload goes up to 120 Mbps. It is 2CA (two carrier aggregation) in DL and UL.
If I leave all the bands allowed, then the modem works at 4CA or 5CA in DL where it reaches up to 360 Mbps (on only 4G) and UL does not aggregate, so upload speeds go up to a maximum of 70-80 Mbps.
