RUTX50 Issues with the admin password
I am having issues with the admin password located on the sticker under the router. Unfortunately it doesn’t work.
Serial number: xxxxxxxxxxx
IMEI: xxxxxxxxxxx
I have also tried the password admin01 but unfortunately it doesn’t work either. What should I do?
Regards
David
Did the password worked before or is it a new device and a first boot of it? Have you tried resetting it to factory settings? What kind of the device is it?
Edvardas
It looks like this isn’t a new device. How have you accessed it before? For the first login, you need the password written on the bottom of the device. Please try factory resetting the device, which will reset the entire configuration and restore the password to its default.
