Rutx50 internal modem disconnect after Fw update SOLVED!
My device has error internal modem not reachable after fw update to 07.12
  • Firmware Version
RUTX_R_00.07.07.1
  • Internal. Modem fw
    RG501QEUAAR12A11M4G_04.201.04.201
Back to 07.07.1
Working fine.
Any suggestions ?
Thank you for reaching out.
Could you let me know the HW of your RUTX50? Additionally, have you tried performing a hard reboot by unplugging and plugging the power cable after the firmware update to 7.12? When the error appeared, was the modem still functioning and able to make a mobile data connection with your ISP?
If the issue persists, I’d like to investigate it further. To proceed with this, I have sent you a form to fill out. Please use 12166 as the ticket ID when completing the form. Once submitted, we will reach out privately and request further details to look deeper into the issue.
Thank you for getting back to me,
to answer your Question see below output of lsusb command and the Hardware details.
Yesterday i did FW update to 07.12 and unplugged Power when ready.
Now running since 14Hours without any issue.
Maybe the Hard Reset should be part of update instructions ?
| _ \ _ | | / _ / |
) | | | | | | | _
| _ <| |
| _\
,|_|__/|____/
Teltonika RUTX series 2025
Device: RUTX50
Kernel: 5.10.229
Firmware: RUTX_R_00.07.12
Build: 51b3ff0af29
Build date: 2025-01-17 11:31:32
root@RUTX50:~# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 002 Device 019: ID 2c7c:0800
Bus 001 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0003
Bus 002 Device 001: ID 1d6b:0003
  • Gerätename
RUTX50
  • Produktcode
RUTX5000XXXX
  • Bootloader Version
2.3
  • Hardware-Revision
0202
  • Chargennummer
0021
Internes Modem
  • Modell
RG501Q-EU
  • FW-Version
