tirkiz
1
Greeting,
how to get via jsonrpc this?
I tried commands:
{ \"jsonrpc\": \"2.0\", \"id\": 1, \"method\": \"call\", \"params\": [\"$session\", \"file\", \"exec\", { \"command\":\"gsmctl\", \"params\": [\"-r\", \"wwan0\"] } ] }
{ \"jsonrpc\": \"2.0\", \"id\": 1, \"method\": \"call\", \"params\": [\"$session\", \"file\", \"exec\", { \"command\":\"gsmctl\", \"params\": [\"-e\", \"wwan0\"] } ] }
…but it returns me only for the active connection, not for this month.
I also tried it for the mob1s1a1 interface, but it returned an error:
gsmctl -r mob1s1a1
gsmctl -e mob1s1a1
AndzejJ
3
You can use ubus commands to get bytes sent/received on the mobile interface:
ubus call mdcollect get '{"period":"month","interface":"mob1s1a1", "sim":1}'
ubus call mdcollect get '{"period":"day","interface":"mob1s1a1", "sim":1}'
Or you can get total:
ubus call mdcollect get_raw_total '{"interface":"mob1s1a1", "sim":1}'
You can then use an online calculator like the one here to convert to MB (in binary).
You can see the format and other mdcollect calls via:
ubus -v list mdcollect
tirkiz
4
works great over SSH.
How to format this into CURL jsonrpc and have it work?
I tried the example:
{ \"jsonrpc\": \"2.0\", \"id\": 1, \"method\": \"call\", \"params\": [\"$session\", \"file\", \"exec\", { \"command\":\"mdcollect\", \"params\": [\"get\",{\"period\":\"month\",\"interface\":\"mob1s1a1\", \"sim\":1}] } ] }
But CURL returns this:
{"jsonrpc":"2.0","id":1,"result":[4]}
AndzejJ
5
Try:
"jsonrpc": "2.0",
"id": 1,
"method": "call",
"params": [
"yourtoken",
"mdcollect",
"get",
"period": "month",
"interface": "mob1s1a1",
"sim": 1
Or with Curl:
curl -X POST -H "Content-Type: application/json" -d '{"jsonrpc": "2.0", "id": 1, "method": "call", "params": ["yourtoken", "mdcollect", "get", {"period": "month", "interface": "mob1s1a1", "sim": 1}]}' http://192.168.1.1/ubus
Just replace yourtoken and the IP address.
tirkiz
6
Thank you very much, everything works
system
Closed
7
