RUTX50 - GSM switching is faild
Hello, my issue with RUTX50 is, when WAN is off, RUTX50 should switch to GSM, but it doesn’t work. During the configuration everything works fine, but a few months later when the test time comes, the switching does not work.
It looks like GSM session is dead. The problem with WAN occurs 2x a year, but it is annoying, as I lose communication with the object for a long time. Switching to GSM was supposed to prevent this.
Do you know how to fix it?
BR, Michał
Could you please specify if you have set up the failover function on your RUTX50? You can refer to the instructions here for guidance.
Yes, I have. I think problem is modem does not refresh session on a sim card.
It appears that you’re using an older version of the WebUI, which might be causing this issue. It’s always recommended to keep your devices updated with the latest firmware versions, as they include improvements and issue fixes.
Please upgrade your RUTX50 to the latest 7.10 firmware version from this link: RUTX50 Firmware Downloads. After upgrading, try replicating the issue and let me know if it resolves the problem, so we can proceed if further action is needed.
I did it and I will test it, Thank You so much!
