RUTX50 GPS Setup v 7.04.3
I have tried to incorporate the GPS feature of the device bit it seems not to be working is there a set up guide I can follow somewhere on how to properly do it. I have enabled it and it still shows No GPS data.Thanks
Please, make sure that the GPS antenna is properly attached and has a clear view of the sky. In RUTX50 Web interface, in should be enough to enable GPS in Services → GPS → General. Then, allow the device some time to obtain coordinates. You should then be able to see your location in Services → GPS → Map .
