Firmware version
RUTX_R_00.07.15.2
Firmware build date
2025-06-25 18:41:49
Kernel version
6.6.87
5ghz Client + 5ghz AP simultaneously is not working on the router. Is this possible and can we fix the same?
The GPS module is not working, it shows No GPS signal, I have the settings for the same turned on and the GPS connected, I can provide the logs/config via ssh if required.
Thank you for reaching out. In this case, to understand the situation and assist you effectively, we’ll need to continue this process privately, because sensitive/publicly unshareable information needs to be gathered. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14641 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
