I have a RUTX50 and a Poynting XPOL-24.
I have a German Telekom DSL LTE/5G Hybrid contract and the corresponding SIM Card.
If I use my other German Telekom MOBIL-Contract SIM CARD… everything is fine and i only need to add my SIM PIN and the APN “internet.telekom” into the Wizard. Thats the good news… So the setup does work with mobil contracts…
Here comes the bad news…
If i use my SIM CARD from the DSL LTE/5G Hybrid contract, i alwasy fail to get something working.
I tried several combinations in the Wizard, but the SIM CARD will not be connected to the Cell.
I had a dialouge with some telekom support and they said, that this contract with DSL AND LTE/5G WILL ONY WORK WITH SPECIAL TELEKOM HARDWARE.
It seems that the german telekom does some checkings in the telekom speedport smart4 that connects the local 5G Cell to the address and the DSL cable and so on…
I am so f… up with the setup and the problems it brings up.
As you know in the RUTX50 Wizard there is following…
APN
Custom APN
Authentication type
Username
Password
PIN
In my Telekom Speedport i have this to set up… (numbers a changed but same length)
DSL Zugang Anbieter: Telekom
Zugangsnummer (T-Online-Nummer): 123456789012
Mitbenutzernummer: 0001
Persönliches Kennwort: 12345678
Anschlusskennnung: 001234567890
In addition i have a SIM PIN, but this is not needed in the telekom router … PIN 1234
Is there any cheat or hope to get the RUTX50 running with my german telekom DSL LTE/5G Hybrid contract?
Is it an idea to set up a router cascade with the RUTX50 and the speedport to get this working… is the RUTX50 WAN port any option?
I am close to give up and send a thousand euros back to my local teltonika dealer…
PLEASE HELP !
kind regards
Vruser
