RUTX50 firmware 7.17.4 "dhcp_mobile.script" hangup
Dear support team,
For RUTX50 firmware 7.17.4 ..
It seems that the script “/lib/netifd/dhcp_mobile.script” hangup as indicated below hence it will not call the user script “/etc/udhcpc.user”.
root@Teltonika-RUTX50:~# ps | grep udhc
9654 udhcpc 1244 S udhcpc -p /var/run/udhcpc/udhcpc-qmimux0.pid -s /lib/netifd/dhcp_mobile.script -f -t 0 -i qmimux0 -x hostname:Teltonika-RUTX50.com -C -R -O 121 -M
9821 udhcpc 2064 R /bin/sh /lib/netifd/dhcp_mobile.script bound
14023 root 1828 S grep udhc
root@Teltonika-RUTX50:~# gsmctl -Y
OK
root@Teltonika-RUTX50:~# [ -f /etc/udhcpc.user ] && echo ok
ok
6043 udhcpc 1244 S udhcpc -p /var/run/udhcpc/udhcpc-qmimux0.pid -s /lib/netifd/dhcp_mobile.script -f -t 0 -i qmimux0 -x hostname:Teltonika-RUTX50.com -C -R -O 121 -M
6200 udhcpc 2064 S /bin/sh /lib/netifd/dhcp_mobile.script bound
9821 udhcpc 2064 S /bin/sh /lib/netifd/dhcp_mobile.script bound
20340 root 1828 S grep udhc
OK
13701 root 1828 S grep udhc
32060 udhcpc 1244 S udhcpc -p /var/run/udhcpc/udhcpc-qmimux0.pid -s /lib/netifd/dhcp_mobile.script -f -t 0 -i qmimux0 -x hostname:Teltonika-RUTX50.com -C -R -O 121 -M
32304 udhcpc 2064 S /bin/sh /lib/netifd/dhcp_mobile.script bound
We hope that you can fix this problem in the new firmware.
Thank you for reaching out and bringing this issue to our attention.
Could you clarify whether it worked properly on previous firmware and on which one, because there weren’t any changes from the mobile backend side?
Nevertheless, in this case, to troubleshoot and investigate this specific matter effectively, we’ll need to continue this process privately, because sensitive/publicly non-shareable information, such as the troubleshoot file containing logs, configurations, serial numbers, etc., needs to be collected.
You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 15655 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
Yes, it was working fine on the previous firmware 7.9.1
Now we shifted to use “/etc/mwan3/mwan3.user” script file which is still called under the latest firmware 7.17.4
I think the technical team can just see if the “/etc/udhcpc.user” script file is called or not.
Hello @Med7at,
Since this issue might be related to the dropped root access starting from firmware 7.17, that could indeed be the cause here. For our developers to better understand and dive deeper into the matter, we’ll need to collect some information that cannot be shared publicly on the forum.
Could you please submit the form that was sent to you so we can proceed with the investigation? Thank you.
But why the “mwan3.user” still working normally!
The developers can easily diagnose the problem to just check if the “udhcpc.user” called or not.
On the other hand, I can’t share any private information related to our company without cyber security permission and they will not accept because we don’t have a signed NDA with your company.
Anyway, I’m ready to answer any questions that may be raised from your developers.
I wanted to let you know that I’ve forwarded this specific issue to our developers for further analysis. Once the investigation is completed and more details are available regarding a potential fix in future releases, I’ll make sure to share the information here.
