RUTX50 – Firmware 07.25.3: Cellular Speed Reduced by 50%
Since updating to firmware 07.25.3, the cellular connection speed has dropped by approximately 50%, despite using the same cell tower, frequency bands, settings, and antenna positions as before.
The current frequency bands are the only ones available on this cell tower, which is also the only tower accessible in this rural area.
The mobile signal is excellent, as shown in the attached pictures. However, the MIMO status fluctuates between 1×1, 2×2 / inactive.
The firmware update is the only change made and is therefore the clear cause of this issue.
Could support investigate the cause and help restore the previous connection speed?
The router is installed at a remote location, and changing settings remotely could result in a complete loss of connection. Therefore, troubleshooting steps must be carefully considered to avoid losing access to the device.
Could someone from the support team please look into this issue and provide an update?
Thank you.
On my RUTX50 things are working well, insofar as large downloads are still downloading at a speed they have always done. General access is also normal.
However the integral speed test has become unreliable, untrustworthy and a puzzle.
If you are subscribing for example an EE UK SIM then a speed test should be via the EE UK network not some other carrier. The speed test at the moment is not to be trusted as reliable at all. It has become useless. Just ignore it!!
Thank you for reaching out.
Could you please confirm whether the lower speed test results are from tests run directly on the router, on connected end devices, or both?
This will help us better understand the behaviour and investigate further.
T.
Hello Tautvydas,
The reduced speed is observed using the RUTX50’s built-in speed test function.
Unfortunately, I’m unable to perform any additional tests because I’m accessing the router remotely and do not have physical access to it.
Thank you for the update.
I will continue investigating this behaviour and update you with my findings. Thank you for your patience in the meantime.
T.
