anyone knows this Firmware is buggy?
The Failover Wifi/Mobile doesn’t work for me.
It is not possible to configure the Failover that Mobile Data generate “no/less” Data if a Wifi Connection is active.
In my case the Data Transfer generates primary data over Mobil.
Has anyone a Configuration Example that woks?
I want to kindly remind you that you should set priorities for the interfaces. If you want WiFi to work as the primary WAN, it should be first on the list, and if you want Mobile to work as the backup WAN, it should be second on the list.
I will need some sensitive information about your device. I have sent you a form to fill out. Once completed, I will contact you privately. Please use ‘6256’ as the ticket ID. Thank You!
