Dear Teltonika Technical Support,
I am experiencing a persistent boot loop issue with a Teltonika RUTX50 router.
Problem description:
The issue started before any firmware recovery or firmware update was attempted.
During normal startup, the mobile signal LEDs begin blinking, followed by the Wi-Fi LEDs. Shortly afterwards, all LEDs turn off and the router restarts. This sequence repeats continuously.
The router is briefly accessible via Ethernet at 192.168.1.1, but connectivity is lost during each reboot.
A continuous ping test shows successful responses (TTL=64), followed by request timeouts and “Destination host unreachable” messages.
The RutOS login page occasionally appears, but the router restarts before I can log in.
Troubleshooting performed after the issue started:
Tested two different original Teltonika power adapters, with no improvement.
Removed the SIM card and disconnected the external antennas, but the issue persisted.
Attempted a factory reset using the RESET button, without success.
Successfully accessed the bootloader recovery interface.
Reinstalled the official RUTX50 firmware through the bootloader recovery procedure, including the October 2026 release.
After firmware recovery, the router continued to exhibit exactly the same reboot loop as before.
Important clarification:
The reboot issue was already present before the firmware recovery procedure. Firmware recovery was attempted as a troubleshooting measure and did not cause the issue or resolve it.
Support request:
Could you please advise whether any further diagnostic procedures are available?
Given that the issue persists with different original power adapters and after firmware recovery, I would also like to request an assessment for possible hardware failure and RMA eligibility.
Device model: Teltonika RUTX50
Serial number: 6009413574
Firmware version installed: RUTX_R_00.07.26.1_WEBUI (flashed)
Thank you for your assistance.
Best regards
