My general use of the internet hasn’t suffered, large downloads still download at a speed i’m familiar with. Nobody in the family has complained about poor or slow connectivity, no buffering or any other problems. Speed tests from desktop PC’s using nperf are consistent with past tests.
My own experience is that the RUT’s integral speed test has become unreliable and to be no longer trusted, broken and no longer fit for purpose. Test results vary wildly depending on the carrier forced upon you from the outset. Prior to 07.25.3 i always got Three UK (My Provider) as my carrier for tests and i’ve always assumed until now that this was normal and test results were always consistant.
For me the carrier should only be the operator your subscribing too and nobody else. You are testing your connection via your own operator, not some other network.
I’m with Three UK, i don’t want a speed test performed via Starlink’s network, or BT’s or on one occasion (Living in the UK) i was once given a carrier in the Netherlands that went bankrupt three years ago!!!
I/we need consistency when performing tests, control. You can’t compare a set of tests from one day to the next when the carriers different from one day to another.
To establish what your speed is i/we need to be able to do tests at different times of the day over many days and find your average and you do so knowing your using the same carrier and server and the carrier should only be your own network provider.
At the mo, i can do a test at 8am and get 50Mb/s with Starlink as the carrier. At 7pm the same day i may get 420Mb/s with Three UK as the carrier.
We can manually select/change a test server. Should we be able to manually set/change the carrier too!?
Not really understanding why a test carrier is allowed to auto select/change randomly from one to another forced upon us, can i assume that being with Three UK and having forced upon me BT as the test carrier, am i basically performing a test as if i was with BT as my network provider!!?? If this is correct, it’s bonkers!! The only advantage would be to be offered the opportunity to manually select a carrier of your own choosing when nearing the end of your current contract to see if another company may be able to give you a better speed before renewing or switching. There are only three UK operators, 4 if you split Vodafone and Three.
Or am i completely misunderstanding the whole thing? For me the RUT’s integral speed test is useless as it is.
