RUTX14 - USB Tools - Samba Share
In the Samba configuration screen there is one paramenter called interface. There is only one selection possible for this parameter: “lan”
Does this mean access to the Samba Share is only possible via lan connection (cable on one of the lan ports) ?
Sorry for the late response. The “interface” parameter in the Samba configuration, with only “lan” as an option, implies that access to the Samba Share is available via the LAN, this includes both wired and wireless connections within the local network.
