my secondary modem is unreachable from a hardware perspective going by the error message which shows a banner that says
“Secondary modem is unreachable”. this is the beggining of the system log from the admin > troubleshooter.
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__write:1097] warning: [CMM] Write to 1-1.2 [2c7c:0306]
modem failed: errno 5
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [common_write_handle:193] warning: [CMM] Failed to send command (0/8 bytes transferred) to 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__init:1034] error: [CMM] Failed to open modem at /dev/
path!
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__init:325] error: [MODEM] Failed to initialize comm manager for 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__new_modem:641] error: [MODEM_MANAGER] Failed to initialize 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__modem_added:450] error: [MODEM_MANAGER] Unable to initialize 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:03 2023 daemon.info gsmd[2862]: [__init:1034] error: [CMM] Failed to open modem at /dev/ttyUSB3
path!
modem!
modem!
modem!
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.413464] usb 1-1.2: new high-speed USB device number 25 using xhci-hcd
Mon Aug 7 19:43:08 2023 daemon.info gsmd[2862]: [__init:1034] error: [CMM] Failed to open modem at /dev/
path!
Mon Aug 7 19:43:08 2023 daemon.info gsmd[2862]: [__init:325] error: [MODEM] Failed to initialize comm manager for 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:08 2023 daemon.info gsmd[2862]: [__new_modem:641] error: [MODEM_MANAGER] Failed to initialize 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:08 2023 daemon.info gsmd[2862]: [__modem_added:450] error: [MODEM_MANAGER] Unable to initialize 1-1.2 [2c7c:0306]
modem!
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.675037] option 1-1.2:1.0: GSM modem (1-port) converter detected
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.675361] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.680912] option 1-1.2:1.1: GSM modem (1-port) converter detected
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.687686] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.694492] option 1-1.2:1.2: GSM modem (1-port) converter detected
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.700625] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.707325] option 1-1.2:1.3: GSM modem (1-port) converter detected
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.713886] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.738640] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
Mon Aug 7 19:43:08 2023 kern.info kernel: [ 735.739993] qmi_wwan 1-1.2:1.4 wwan0: register ‘qmi_wwan’ at usb-xhci-hcd.0.auto-1.2, WWAN/QMI device, 2e:87:1b:b9:e0:91
Mon Aug 7 19:43:48 2023 daemon.info gsmd[2862]: [check_req_timeout:104] error: [MODEM_MANAGER] Warning: request reached timeout (10s) on 1-1.2 [2c7c:0306]
modem!
the secondary sim card works in the primary slot, so there is no issue with the sim.
When i log into the CLI as admin from the webgui, after entering the correct password, it says (cant change directory to ‘/user’) and then session closes and disconnects. this unit is still under 2 years for warranty
thanks
