RUTX12 Relayd DHCP to RUTX50 distribute wrong IP
try to use Relayd DHCP on two RUTX like in example → Relayd - Teltonika Networks Wiki
but receive wrong IP from pool RUTX12(LAN) , example in point 3 → DHCP Relay configuration example - Teltonika Networks Wiki if delete this pool on RUTX50 in loogs see error about wrong IP range and RUX12 not take any IP to PC connected to LAN port.
I’m want to use the same LAN network on bouth RUTX
shematic.
Thanks for reaching us.
Kindly can you provide screenshots of your configuration to try to sort the issue out together?
Hi, lets try:
RUTX50 (MASTER)
LAN:
additional DHCP rule:
RUX12(SLAVE)
WIFI
WAN
LAN
PC on LAN port
RUTX12_PC_receive_IP
