We have 2 RUTX12 routers that are being used with Starlink. Starlink is the primary connection and cellular is set as secondary with failover. The Starlink is in bypass mode.
Daily the connection loses “internet” but ping traffic still passes. At first we thought it was a HTTP issue but on the second unit it appears that DHCP stops handing out leases.
To “fix” the issue we have a daily reboot but would really like a more permanent solution as sometimes this isn’t enough.
Firmware is on 7.04.4
Anyone else seen this?
