RUTX12 after restoring factory settings
I had to restore my RUTX12 modem to factory settings. After reconfiguring my settings, I can’t connect via RMS. There’s a triangle and a message that it can’t confirm the authenticity of the device. You can see that the modems are working but there’s no control over it. It shows offline. What should I do?
Thanks for reaching out!
After you factory resetted your RUTX12, your router’s password is also changed. You can try to unregistering and registering again! If your router has internet connection, there shouldn’t be any issue!
Caner
Thanks for your answer, but when I try to add the device again on the RMS website, after entering the name and serial number, it asks for a password. What password should I use? I enter the admin password and nothing.
The default password of the router after a factory reset.
It is the one from the sticker on the bottom of the device.
Small update. It’s up and running.
Good to hear mate :slight_smile:
I’m glad the issue is resolved!
Thanks @TeWe!
Please let me know if any further help is needed on this topic @Zoltar
Caner
Not on this topic anymore.
I have a question about pairing EYE temperature sensors with my RUTX12. What do I need to do to read the temperature remotely?
Thank you.
I’m glad that the issue is resolved.
To keep community forum well organised, I need to ask to you open new query!
Thanks for understanding,
Caner
This topic was automatically closed 2 minutes after the last reply. New replies are no longer allowed.
