RUTX11 - WPA2-EAP, MSCHAPv2 has stopped working
After update firmware above 00.07.06.3 we have problem with login/authenticate do AccessPoint.
WPA_supplicant logs:
daemon.notice wpa_supplicant[28133]: SSL: SSL3 alert: write (local SSL3 detected an error):fatal:handshake failure
daemon.notice wpa_supplicant[28133]: OpenSSL: openssl_handshake - SSL_connect error:0A000152:SSL routines::unsafe legacy renegotiation disabled
daemon.notice wpa_supplicant[28133]: TLS handshake failed due to the server not supporting safe renegotiation (RFC 5746); phase1 parameter allow_unsafe_renegotiation=1 can be used to work around this
daemon.notice wpa_supplicant[28133]: wlan1: CTRL-EVENT-EAP-FAILURE EAP authentication failed
Wireless security configuration:
How we can manually put/insert/pass this parameter: allow_unsafe_renegotiation to wpa_supplicant.conf or maybe even to /etc/config/wireless ?
We can’t change (has no possibility) AccessPoint/SSID_Network configuration change.
Is anyone reading this?
What is the point of a support service if most questions/problems are not answered?
If you can share more information on this one.
Did you had a clean upgrade while upgrading i.e. not keeping old settings while upgrading?
lets us address this issue in helpdesk with on going query we have.
