RUTX11 - WAN Daisy chain
Is it possible to configure a daisy chain/switch functionality on the WAN interface?
We would like to connect several routers in line, one behind the other.
For example: corporate network on WAN port router 1, then LAN3 router 1 to WAN router 2, then LAN3 router 2 to WAN router 3, and so on.
This can work, however, it is not recommended, since the traffic will be NATed multiple times - where the IP packet will go on multiple hops to reach the destination network causing a decrease in network speed and stability.
Robert
